03-08-2017
17:19
08:32
YojanaFitbit
03-08-2017
17:19
08:32
YojanaFitbit
I have a surge fitbit, I am wonderin
g if I do spinning in exercise mode, does it give you step count as well
Moderator edit: Clarified subject.
03-08-2017 21:13
03-08-2017 21:13
Yes it should
Wendy | CA | Moto G6 Android
03-09-2017 08:31 - edited 03-09-2017 08:34
Hi @SunsetRunner! Thanks for popping by the forums. As @WendyB said, it will sense a couple of steps gathered from the movements of hand, since your tracker was desinged to track step based routines, They won't be that many, so it won't affect your overall stats for the day. Most of the time after you sync your spinning activity you will see Step recorded as N/A (not applicable).
You should definitely give it a try to see how this works for you. On the Shortcuts in the Fitbit Surge display, pick the option "Spinning". If it is not there you can add it.
I'll be around in case you have more questions!
