02-21-2018
04:05
12:03
YojanaFitbit
02-21-2018
04:05
12:03
YojanaFitbit
i dont have the dongle how can i sync the workouts to my computer?
02-21-2018 04:24
02-21-2018 04:24
If your computer is running windows 10 and it has built-in bluetooth then you won't need a fitbit dongle as the fitbit app will be able to use the computer's bluetooth.
If you are running windows 7 or 8 then you won't be able to sync using it unless you buy a fitbit dongle.
02-21-2018 04:32
02-21-2018 04:32
02-21-2018 05:22
02-21-2018 05:22
Sorry but I don't understand. What are you trying to sync your fitbit to?
Have you tried using your phone instead of a computer? If yours is supported by fitbit (see www.fitbit.com/devices ) then you won't need the dongle.
02-21-2018 06:05
02-21-2018 06:05
02-21-2018 06:07
02-21-2018 06:07
ok, as long as you have bluetooth on your computer then go to the windows store and download the fitbit app. This should sync your data without needing a fitbit dongle.
02-21-2018 12:10 - edited 02-21-2018 12:14
Hi, @haima123 thanks for stopping by, welcome! It's great to see your participation in the forums @SteveH. ![]()
As @SteveH mentioned you can download the Fitbit App here, and if your computer has built in Bluetooth you will be able to follow the instructions and connect your Fitbit.
You can also use a mobile device if it is listed here. And follow these instructions.
Hope this helps.
