10-19-2017 16:01
10-19-2017 16:01
I bought Surge on March 2017, facing battery drain oit within a day and Bluetooth cannot connect issue. After exchange a new device, same problem happen on Oct 2017.
I doubt why surge always getting same problem in 3 mth and need to exchange.
Hiw about after warranty period?
Best Answer10-19-2017 16:10
10-19-2017 16:10
I stay at Singapore. The service center always out of stock for exchange.
How can Fitbit help me???
I am very disappointed to this product.
Best Answer10-20-2017 01:47
10-20-2017 01:47
@CCLee I would return the 2nd bad unit as soon as possible for a refund for 2 reasons. 1) After the warranty is up you are on your own. Fitbit WILL NOT replace it even if it fails for the same reason. 2) The Surge has been discontinued and replaced by the Ionic. Support for the Surge is minimal. Good Luck.
10-20-2017 21:49
10-20-2017 21:49
May i know, how did you made the exchange?
Best Answer10-21-2017 05:53 - edited 10-21-2017 06:03
@CCLee Your original Surge was bought in March of 2017 so the warranty is good until March of 2018. You are entitled to "warranty" replacements to the end of March 2018. Contact Customer Service, tell them the problems your current Surge is having and if they can't help you get it up and running, request another replacement. At the bottom of the Community home page you should find Fitbit: "About Us", "Careers", etc. and "Help". Click on Help and select your the way you wish to contact Fitbit for assistance in replacing your Surge. Hope this helps.
Best Answer10-21-2017 19:26
10-21-2017 19:26
I had contact Fitbit local sales representative. According to them, all incoming stock is pink color. I need black or blue. They say US side did not ship this two color to them. Need to wait .......i did not know how long to “wait”
Is it wait until expire and no need to exchange??
Please advice on this issue.
Thx
