10-03-2018 19:38
10-03-2018 19:38
Best Answer10-03-2018 21:16
10-03-2018 21:16
Welcome to the forums!
Calorie burn depends on your BMR
You burn calories just by being alive! Even Sleeping. Fitbit includes these burned calories in it's calorie calculations, so even if you did not wear the fitbit, you'll still burn these calories.
Read this
Check out the discussions boards! A lot going on and I'm sure you have some contributions as well!
Hope to see you around!
Wendy | CA | Moto G6 Android
10-04-2018 07:07 - edited 10-04-2018 07:09
Thanks for the reply Wendy! I do understand BMR and that I burn calories by just being alive my concern is that my Fitbit is overestimating my calories when I forget to turn off exercise mode. Example:
Wearing Fitbit from 12pm-1pm NOT in exercise mode- 100 calories burned, heart rate consistently 52bpm
Wearing fitbit from 6:30pm-7:30pm IN last exercise mode used however class ended at 6:15- 160 calories burned, heart rate consistently 52bpm
It seems as though Fitbit is overestimating my calorie burn just because I’m not out of exercise mode. In these two examples my activity levels during these two hours are very similar. I hope this helps! Thanks 😊
