06-23-2018
04:48
10:13
YojanaFitbit
06-23-2018
04:48
10:13
YojanaFitbit
Hi All,
I was wondering can you have a factory reset on Surge? Thinking about giving it away - I have had it for 2 years and still in great condition - I had an upgrade to Fitbit Versa that I bought today and I think will be happy with it.
Many thanks 🙂
Moderator edit: Updated subject for clarity.
06-23-2018 06:17
06-23-2018 06:17
It will reset it self when who ever you give it to sets it up. Just sync one last time before turing it over
Wendy | CA | Moto G6 Android
06-23-2018 06:17
06-23-2018 06:17
06-23-2018 18:40
06-29-2018 10:17
06-29-2018 10:17
@SunsetRunner Hope you're doing well, and enjoying some healthy activities! ![]()
I noticed that @WendyB has offered you a really good suggestion to resolve your inquiry. If so, I invite you to mark this post as the solution. Marking posts as solutions is a great way of thanking another community member, while also highlighting their solution; so that it may be discovered more easily by other community member's facing the same questions or issues as you. You can read more about Accepted Solutions.
If you have more questions about it, I’ll be more than glad to lend you a hand with that!
Please keep me posted!
Best Answer07-26-2018 14:26
07-26-2018 14:26
It didn't work the way you suggested.
When it was was removed from one account and then added and synched to another account, all the data (step count, rest rates, etc), and even some settings, were added to the new account. It even produced a few "trophies".
Any idea how how to fix this?
Is there a way way to remove data from an account or reset it?
is there a way to physically factory reset/restore a Fitbit Surge (by button press, etc) to wipe all the current data?
Thanks for your help with this
07-27-2018 13:50 - edited 07-27-2018 13:55
Hi @ATektoo thanks for stopping by! Thanks for joining this family, hope you like what find here! ![]()
Thanks for trying the suggested steps. This is an unexpected behavior the one that you're sharing, as it shouldn't be transferring that data or trophies to the new Fitbit Account. The only possible solution is to delete this Fitbit Account, then wait for the deleting process to finish, to recreate the account again to start from zero. It takes time and you will have to do it directly with support team. I can open a case for you if you wish or you can reach them out directly to get a faster response. ![]()
Now about the factory reset to wipe all data, it should be enough just to give a last sync in the old account, restart the Fitbit and then pair it in a new account. I'm not sure what happened in your case, but there is no other way. You can create a new account using a second email address to see if this works this time. Sorry for the inconvenience you've had during this process. ![]()
Let me know what you decided to do.
