11-07-2016 21:13
11-07-2016 21:13
11-07-2016 21:16
11-07-2016 21:16
11-07-2016 22:03
11-07-2016 22:03
Hello @CW0523,
Welcome to the community!
When you got your new phone did you select "Log in" or "Join Fitbit". If you did the latter, then you created a brand new account instead of logging into your existing account.
Log out, and log back in with the same e-mail and password you used to establish your account. You'll also need to pair your tracker back to your old account.
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
11-08-2016 05:11
11-08-2016 05:11
11-08-2016 13:09
11-08-2016 13:09
Honestly, it sounds like you logged in to the wrong account. Everything you describe (lost history, no tracker, no friends) will indicate that.
How about trying this:
I'm speculating that these two e-mail addresses are different... that when you got your new phone instead of selecting "Log in", you selected "Join Fitbit".
If these are different, just log out of the application (very bottom of the accounts page) and then log in with the e-mail from step #2 above. You'll also want to re-pair your Surge with your old account.
I hope this helps.
11-08-2016 14:25
11-08-2016 14:25
11-08-2016 14:31
11-08-2016 14:31
Woo Hoo! Happy Dance!
11-08-2016 14:55
11-08-2016 14:55
11-17-2016 08:31
11-17-2016 08:31
@CW0523 Hope you're doing well, and enjoying some healthy activities!
I noticed that @PureEvil has offered a few suggestions to help resolve your issue. If so, I invite you to mark this post as the solution. Marking posts as solutions is a great way of thanking another community member while also highlighting their solution so that it may be discovered more easily by other community member's facing the same questions or issues as you. You can read more about Accepted Solutions here.
If this didn't resolve your question, or you're still unclear on this, let us know and we'll be happy to work through it with you.
