03-07-2016
11:24
18:42
EstuardoFitbit
03-07-2016
11:24
18:42
EstuardoFitbit
Hey guys,
I guess the title says it all! I can't seem to connect to GPRS anywhere in either home or London (whilst at work) and I don't know why!
I've tried the following:
Any ideas for what could be causing this?
Thanks,
Luke
Moderator Edit: Subject for clarity
Best Answer03-07-2016 12:26
03-07-2016 12:26
GPRS, or GPS ?
Best Answer03-07-2016 13:13
03-07-2016 13:13
Best Answer03-07-2016 23:06 - edited 03-07-2016 23:08
GPRS is for phone communication
GSM, GPRS, Edge, H+, 2G, 3G, 4G, and so on.
Surge is not a phone
GPS is for localisation by satellites
GPS doesn't run well inside home or with buildings or trees around, it must "see" satellites
Best Answer03-07-2016 23:42
03-07-2016 23:42
Best Answer03-08-2016 04:21
03-08-2016 04:21
yeah, try outside...
Best Answer03-08-2016 04:27
03-08-2016 04:27
Best Answer03-08-2016 05:59
03-08-2016 05:59
@CanOfCreamSoda wrote:
Ok cool, so any ideas?!
Sent from my iPhone
for ?
do the GPS working inside ?
not possible.
Best Answer03-08-2016 06:21
03-08-2016 06:21
Hey guys,
Not inside, It's when I'm outside going for a run. Used to connect fine, now won't. Lame!
Luke
Best Answer04-27-2016 14:56
04-27-2016 14:56
Welcome to the Community @CanOfCreamSoda! If you're still having issues with your GPS connection. I recommend restarting your Surge:
Some times high buildings, several trees may impact your GPS connection. Since you mentioned that your Surge gets stuck on Quick Start, you may want to try to use MobileRun. To know more about this, take a look at this post.
Good luck!
Best Answer04-27-2016 20:49
04-27-2016 20:49
The other thing I would do is through the settings on the Surge, shut the Surge down. Now start it by pressing any button.
