06-20-2017 07:55
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
06-20-2017 07:55
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Fitbit Surge screen is too dim to read and is flashing - unable to reset or turn off
Accepted Solutions
06-20-2017 08:02 - edited 06-20-2017 08:04
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
That would be moisture @bshelmer (been there, done that)
Grab a ziplock bag and fill it 1/3 full of dry raw rice, drop your Surge in the sealed ziplock for a day or two then pull it out and hold the left and bottom right buttons together until the display brightens then slowly dims to shutoff. There should be enough battery life if you've charged it within the last couple of days, otherwise you may have to hook up your charge cable for 10 minutes before resuscitating your best bud!
Remember the Surge has an altimeter hole, anything short of a mist will creep into the inner works through the access hole, all good - you can do this, just a matter of drying things out, the rice will create a temporary mini desert for it. Thanks for asking!
If the dry out procedure doesn't work for you contact customer service for more options, if it does, come back and share your story. Great to meet you.
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
WmChapman | TX
06-20-2017 08:09
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
06-20-2017 08:09
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
- Who Voted for this post?
Sent from my iPhone
