05-29-2020 07:07
05-29-2020 07:07
My Fitbit surge isn’t working. It showed full battery when connected to the charger. But gets switched off when disconnected. Looks like a battery issue. Why is the battery so substandard for a gadget I spent ₹20k on?
I need immediate resolution as you don’t have any service Centers for such repairs.
Best Answer05-29-2020 22:26
05-29-2020 22:26
They are not repairable.
How ever if you search Youtube for battery replacement and the model you will find some tutorials to help you
Wendy | CA | Moto G6 Android
05-30-2020 12:16
05-30-2020 12:16
@sunilraot unsure how you're calling years of usage substandard? Li-ion batteries are rated for 3 years generally, whether in a remote-controlled helicopter or a Fitbit tracker. If you paid 20k Rupees for this, you likely purchased in 2015 and got a fantastic 5-years out of this fine device 🙂
IDK how much the batteries run, as @WendyB shared, there are videos with instructions on YouTube. There are also 3rd party service centers that average $50USD to replace batteries in the Surge, and you can find used and refurbished Surge trackers on eBay between $20-40USD.
Alternately, consider this an opportunity to get a newer Fitbit model. Cheers!
05-30-2020 22:46
05-30-2020 22:46
@Williger Guess you are too fast to jump into conclusions! It isn't a 2015 model so your response is actually irrelevant.
Thank you anyways!
Best Answer05-30-2020 22:50
05-30-2020 22:50
@WendyB Thanks for the suggestion. Unfortunately we do not get the spare battery here in India. May have to import it from China. I have anyways shifted to Apple Watch. My wife wanted to use the Fitbit device, but guess it's not gonna happen in near future.
Best Answer06-08-2020 23:19
06-08-2020 23:19
@sunilraot you're welcome. Those links will help you no matter what the year of the One. It's out of its service period, so replace the battery or purchase a new tracker. Cheers.
