02-09-2017 15:24
02-09-2017 15:24
The screen on my Surge has an obnoxious flashing. It pulses on/off and about a 1 second frequency. I've stopped using it and reverted to my Flex - BUT that will no longer sync with my iphone after having done so for a couple years. Nothing lasts forever, but very frustrating.
02-09-2017 20:58
02-09-2017 20:58
Try a restart. Do it at least 3 times.
Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
If that doesn't help
Contact Support
http://help.fitbit.com/?cu=1
Wendy | CA | Moto G6 Android
02-10-2017 06:45
02-10-2017 06:45
Hey @Maurelli, thank you for joining us! ![]()
Sorry to read about your Surge, as @WendyB said our best recommendation is to contact our Support Team, they can check your information and provide you with the best solution based in your Fitbit warranty. You can reach them via email, or if you prefer you can chat or calling them at:
Keep me posted with the outcome! ![]()
Best Answer02-13-2017 10:29
02-13-2017 10:29
I restarted more than the recommended 3 times to no avail. A restart DID work on my Flex which had stopped syncing and it now is working again. I'm not interested in ranting here, but the 2 Fitbit items that I own have performed FAR below what seems reasonable. Very disappointed.
02-14-2017 08:38
02-14-2017 08:38
Hi there @Maurelli! Thanks a million for the feedback, and don't worry; I don't think that you're ranting. Feel free to share how you feel here. I totally understand why you share your thoughts about your Fitbit trackers, as it's odd you're having issues with both. ![]()
Did you contact Customer Support, they have tools that can help to research to determine what is happening with your little buddies!
I'll be waiting for your response. ![]()
Best Answer02-17-2017 10:07
02-17-2017 10:07
I did contact tech support. I was first in auto-message purgatory, then put on hold for the next "advocate". Once an advocate came on, they wanted my phone number and the case number for this e-string. I'm at work and have other things to do. It appears you use your malfunctioning equipment as an opportunity to collect personal information instead of support. I become more negative about your company with each successive interaction. I hung up.
02-21-2017 11:16 - edited 02-21-2017 11:16
Hi @Maurelli! Thanks for getting back! Sorry to hear about your experience with Customer Support. over the phone. If you feel more confortable chatting, you can do so! Remember that you can email them too if you wish. I know that you're really busy but I'm sure that they will be more than happy to keep assisting you.
Give it a try and let me know if you need anything else!
