Welcome to the Fitbit Community @daveaj! You should start by checking out these syncing troubleshoots. Make sure that there isn't another Bluetooth device that may be creating interference during the process. Setting up your tracker as a new device may also help you to bring it back to sync as usual.
Hope this helps. Let me know the outcome.
Best AnswerWelcome to the Fitbit Community @daveaj! You should start by checking out these syncing troubleshoots. Make sure that there isn't another Bluetooth device that may be creating interference during the process. Setting up your tracker as a new device may also help you to bring it back to sync as usual.
