01-20-2017 19:35
01-20-2017 19:35
I am not able to get my GO SMS Pro text message app to tell my Surge that I have a new message. When I select FB Messanger in the FitBit app, they will come through, so I think I have the settings correct in the Surge and the FitBit app, but what is it about GO SMS Pro that is causing the block in communication with Surge? Calls work fine, music works, just texting is my issue...with GO SMS Pro.
Any ideas?
01-24-2017 06:03 - edited 01-24-2017 06:05
It's great to see that you've visited the Fitbit Community @junglejeb! Welcome to the Forums. The idea of using the GO SMS Pro App is terrific, but it is not compatible to sync with your Surge; as far as I know. Have you tried to use the regular text messages to see if they are connecting? Read more information on how to connect text messages in this master post. ![]()
I recommend to post this request information in our Feature Suggestions board where our developers can check what our Fitbitters need and take this in consideration for the next updates.
I'll be around Have an awesome day! ![]()
