06-20-2017
01:18
08:45
YojanaFitbit
06-20-2017
01:18
08:45
YojanaFitbit
I can't see the stripe under or up the heart, for the zones?
06-22-2017 08:42 - edited 12-08-2017 09:24
I've noticed you are new around @Binneke, so let me give you a warm welcome to our Community!
Excellent question! Heart-rate zones help you target the training intensity of your choice. Usually, you get that information while you're working out. Have you noticed if your Surge shows those details in your training routines?
You can restart your Surge if you wish to see if this helps! Please keep me posted!
I'll be around!
06-25-2017 06:14
06-25-2017 06:14
06-27-2017 14:48
06-27-2017 14:48
The heart zone indicator functioned very well in the beginning but now it does not indicate anymore weather I'm burning fat or I'm in the peak zone.
It only indicates heart beats.
I have the fitbit surge for 14 days only.
06-30-2017 09:21 - edited 06-30-2017 10:19
Hi @Binneke! Thanks for the details!
In order to help your little buddy please perform a restart to your Surge as I mentioned above and change the HR Settings on your Surge to "On" sync it and then change it to "Auto" and sync it again. Then you can test it out and let me know how this works for you.
Give it a try and keep me posted!
