09-09-2017 01:37
09-09-2017 01:37
My surge is displaying red light on the right side and seems there is a lot of condensation under the screen . It keeps flashing and I'm unable to switch it off. Can someone help please ?
09-09-2017 04:38
09-09-2017 04:38
@Gina.T Hi Gina T. You have moisture under the screen. Place the Surge in a small bag of uncooked rice to draw the moisture out. This may take a day or two. The red LED may be due to the moisture. While the surge is "drying out", allow the battery to drain to zero. This would be about 24 hours after the red LED goes out and the display goes blank. Then recharge and restart. Now for the bad news. Since moisture got in once it will do so again. The Surge has a bad seal.There is no fix for this. If your Surge is still under warranty call Customer Support for assistance. Good luck.
09-09-2017 04:53
09-09-2017 04:53
Thank you for the info. I'll try that, but my question how did the moisture get in ? I never used it near water as I know it's not waterproof. Now to the bad news, I don't have the receipt as it was a Christmas gift and I only started using it 4 months ago.
09-09-2017 05:11
09-09-2017 05:11
@Gina.T Your Surge has a bad seal and even humidity (water vapor) can get inside. Tell Customer Support it was a gift. They can determine when your Surge was "activated." They are usually very helpful.
09-09-2017 06:30
09-09-2017 06:30
Thank you so much for your support . Can you plz tell me how to contact customer support or send me their no in Australia ? Thanks .
Best Answer09-09-2017 06:39
09-09-2017 06:39
@Gina.T http://help.fitbit.com/ Good luck!
09-09-2017 15:35
