Easy enough, sync one last time, remove (or forget) it from your mobile's bluetooth list and hand it over to her.
Have her load the fitbit app on her mobile and follow the "new user" dialog to set up.
Important she use her own unique email address and password going forward. All your data is stored under your email address login should you ever want to review that history on your mobile or add another tracker...
If you decide later to share your surge, remove (or forget) it from her mobile's bluetooth and let your mobile's discover mode find and add it back to your account.
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
