04-16-2017
10:10
13:30
MariamV
04-16-2017
10:10
13:30
MariamV
My wife got a new surge and I made a new account (different email) to use her old one. All of her steps data is now in my account from when she was using it. I'd like to clear it. I could use some help.
Moderator edit: updated subject for clairity
Best Answer04-18-2017 15:50
04-18-2017 15:50
@Grit2 thanks for getting back to me! That sounds about right.
If your wife didn't sync before giving you her tracker then that info will definitely be transferred to your own personal account. That's brilliant! I'm glad to read that our Support Team helped you out with this. They're wonderful! ![]()
Please post back with the outcome after waiting for the timeout. I'll be looking forward to your new comments!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
Best Answer04-17-2017 13:46
04-17-2017 13:46
@Grit2 welcome aboard! That's pretty weird.
Usually when you set up a tracker to a new Fitbit account all of the former owner's info should be deleted. If possible, please post me a screenshot about it so that I can further analyze. I'll be looking forward to your new comments!
Oh, and a restart might do the trick. Please try the following:
Give that a try and let me know how it goes!
04-18-2017 12:37
04-18-2017 12:37
04-18-2017 15:50
04-18-2017 15:50
