12-28-2020 02:36
12-28-2020 02:36
Surge is not recording the hourly 250 steps properly. It is temperamental and not consistently registering it or sometimes deletes already recorded data
Best Answer12-31-2020 19:58
12-31-2020 19:58
How have you determined this? Do you carry a second tracker that's reflecting differently?
Best Answer01-01-2021 12:27
01-01-2021 12:27
Best Answer01-01-2021 21:43
01-01-2021 21:43
What's probably happening is the tracker takes a few steps to start recording steps, this is intentional to prevent accidental steps let's say just reaching for the phone when sitting, so it makes sense you'd "lose" a few, but if you're consistently moving and you have your stride length set correctly, it should be rather accurate. I've tried testing multiple trackers even before, sometimes they're off by a few steps for shorter steps like we're talking but for the overall day, relatively on target.
Best Answer01-02-2021 01:07
01-02-2021 01:07
Best Answer01-05-2021 20:06
01-05-2021 20:06
@Siva007 YW. You can improve accuracy slightly with the stride length; how Fitbit assumes our steps based on our leg length, but from my testing, even different Fitbits will track slightly different (tried using one not connected to my account and the same model connected and still a bit different). Comparing multiple trackers over the course of 24 hours they will all be different by several hundred steps. Overall, even if not completely accurate, it's fantastically motivating!
