02-24-2016 23:50
02-24-2016 23:50
How can I change the phone number that my Fitbit is linked to? I have a new phone number now, downloaded the app on my new phone, but I don't get a notification when I get an incoming phone call now that I'm using a different phone number. ![]()
02-25-2016 04:33
02-25-2016 04:33
02-25-2016 04:51
02-25-2016 04:51
02-24-2016 23:57
02-24-2016 23:57
the Surge is not linked to a phone number, but to a terminal
you have to associate it
02-25-2016 00:26
02-25-2016 00:26
Thanks for the answer 🙂 But i still dont get it, its hard to understad everything in english text / guidance
🙂 If u have the time can u please help me more direct to what im supose to do? Thank you![]()
Best Answer02-25-2016 04:33
02-25-2016 04:33
02-25-2016 04:40
02-25-2016 04:40
02-25-2016 04:51
02-25-2016 04:51
02-25-2016 04:54
02-25-2016 04:54
Best Answer02-25-2016 05:11
02-25-2016 05:11
02-25-2016 05:14
02-25-2016 05:14
NOW its working
Thank u ![]()
Best Answer02-25-2016 05:24
02-25-2016 05:24
Best Answer04-30-2017 16:36
04-30-2017 16:36
I gave wrong Mobil number
09-18-2018 01:12
09-18-2018 01:12
how can you turn on notifications in the Fitbit app, or synced your surge with your new phone when you dont know how to change old cell or disconnected number to your current or updated cell number???
Best Answer09-18-2018 01:20
09-18-2018 01:20
unfortunately hunnie they are not answering your question directly. I think they did not comprehend the "new" or "diffrent" number that the fit bit was originally set up to. Ive been struggling with this exact problem for the past 9 or 10 months. And I get that too, there is no understanding we all are not born with 1 telephone number and carry that number with us for the rest of our lives (like a social security number). i hope you find a solution such a waist of a couple hundreds of dollars you can only use as long as phone you have at that moment works I will keep an eye out for you too should I come across a solution 🙂
Best Answer09-12-2021 17:33
09-12-2021 17:33
Go into your account, 2 factor authentication, turn OFF 2 factor authentication, change your phone number there, then turn 2 factor back on. Good luck!
