01-01-2016
16:15
06:43
CindyFitbit
01-01-2016
16:15
06:43
CindyFitbit
How do you change the run setting to walk on the Surge?
Best Answer01-09-2019 12:57 - edited 01-09-2019 13:02
Hi @Mfmacdougall welcome, I'm glad to see you here in the Forums, your comments are very important for us! ![]()
Thanks for the steps you've tried until now. You can remove shortcuts on you Fitbit App by tapping on your your Charge 2 > tap on Exercise Shortcuts > swipe left on any shortcut to remove or drag handles to reorder. Then remember to sync your tracker to see the changes done. If this doesn't help you can restart your Fitbit Charge 2 too.
Let me know how this works for you.
01-14-2019
05:13
06:32
YojanaFitbit
01-14-2019
05:13
06:32
YojanaFitbit
When I go into exercise I don’t have walking option. Also does Fitbit versa track all movement and nit just steps if so I would really like help in getting the walking option so I can keep track Thx
How do you add the walking option. It’s not on here. Thx
01-15-2019 06:56
01-15-2019 06:56
Hey there, @Terry-6265! How are you?
Why don't you check in the Fitbit App under > Account > Versa > Exercise Shortcuts > + sign in the upper right corner. If you have 7 existing exercises there, you might have to delete one by swiping left on any shortcut to remove it.
Let me know how this worked for you!
01-15-2019 17:31
01-15-2019 17:31
Best Answer01-16-2019 12:23
01-16-2019 12:23
Thank you for getting back to us and for describing the steps you have followed @Terry-6265.
Fitbit devices have a finely tuned algorithm for step counting. The algorithm is designed to look for intensity and motion patterns that are most indicative of people walking and running. When working at a desk, cooking, or doing other arm movements, a device on your wrist can pick up some extra steps if it thinks you're walking. Many of these situations—such as working or cooking—do include a few steps in-between stationary periods so the device tries to give you credit for those steps.
I recommend changing your Surge wrist setting to non-dominant wrist. The non-dominant wrist setting increases the sensitivity of step counting and should reduce any under counting of steps. Non-dominant is the default.
Please let me know how it goes.
06:24
14:15
JuanJoFitbit
11-18-2019
06:24
14:15
JuanJoFitbit
Removing, syncing, adding walk, syncing again is just not working for me. 😞 Are there any other suggestions?
After following the instructions I am still left with run, bike, swim, treadmill, weights, interval 1. I have no walk or hike. I have ignored and saved all of those options, synced and they are still there.
It shows on my phone not on my fitbit: run, walk, hike. The only things I want on my charge hr are walk, aerobic, and swim. I don't always need a map.
I must be missing something here because it says Jogger, so it looks like the question has been answered, but it shows no answer here. I am having trouble with this fitbit and need help. I don't feel I am getting it. Nothing I have read is working.
Moderator edit: merged replies
17:15
14:13
JuanJoFitbit
12-01-2019
17:15
14:13
JuanJoFitbit
Did you change the settings on the dashboard on your computer? That's where you can edit the settings.
Moderator edit: merged reply
Best Answer11-04-2020 17:47
11-04-2020 17:47
There is no "shortcuts"
