06-27-2016 12:44
06-27-2016 12:44
Best Answer06-27-2016 15:24
06-27-2016 15:24
On your computer Dashboard You should see this:
Thats what you need to click on and you will see a drop down box to select Settings
Wendy | CA | Moto G6 Android
Best Answer06-27-2016 13:30
06-27-2016 13:30
On your Dashboard Click on the gear and go to settings. Scroll down to time and use the drop down to select 24 hr. It will need to sync before it takes place
Welcome to the forums!
Best Answer06-27-2016 13:51
06-27-2016 15:07
06-27-2016 15:07
06-27-2016 15:24
