01-23-2017
10:10
05:17
YojanaFitbit
01-23-2017
10:10
05:17
YojanaFitbit
I accidently left the GPS while driving after then end of my activity. I thought there was a way to edit the finish of an activity but I can't find it. I want to cut out everything after point 3. Any ideas of what I am missing?
Thank you
Moderator edit: Clarified subject.
How you doing my friend @theotherShane? Welcome! Multi-Sport don't let you edit your activities unless you're using the "Workout" option. You might delete the activity and manually enter it again with the correct information regarding duration. This is in the case that you want to have a better calculation for calories burned. Please note that if you do so, the map information won't be there, as it is transferred just during the first synchronization of your Surge, after you finished the activity.
All the rest of stats are saved on the Surge memory (distance, calories, steps). You can do those changes by going to your Fitbit App > "Track exercise" (this tile has the pic of a little man running) > Select Activity > Delete. To add the activity back, go to the same tile "Track exercise" > Select stop watch (upper right corner) > Log > enter information. ![]()
If you have any further questions, please let me know! ![]()
