05-05-2016
19:08
20:16
EdsonFitbit
05-05-2016
19:08
20:16
EdsonFitbit
Time has been off by 20 minutes for several days....turned off turned on changed time zones...nothing works.
Welcome to the Fitbit Community @Bumpy. It's great to have you here. I would recommend setting up your Surge as a replacement device. This should fix your time issue.
Thanks for stopping by, see you around. ![]()
