08-28-2016 10:37 - edited 08-28-2016 11:19
Hello, i really need some helps here
I just bought new fitbit surge today from a famous retail store in Thailand. I was in a rush and didn't check the box and what's inside. When i came home and unboxing it...seems to me that the box was opened before. there's a tear in a barcode, some scratches on the clear plastic cover and the charger wire doesn't have any plastic wrap on it. Also the plastic that black hole on the bottom of the box was already peeled off and sticked to the inner side of the box. anyways to tell if this has been used before? when i turn in on for the firs time it has 1302 calories burnt thank you.
Best Answer08-28-2016 11:55
08-28-2016 11:55
Hello and welcome to the forums @fluffypuppy
When you first get your Fitbit, you will see burned calories. The devices begin the day at midnight, so no matter what time you set up, those burned calories will be there. This article on burned calories may help you. click to read
What you're seeing is normal and won't make any difference with your step statistics.
08-28-2016 13:52
08-28-2016 13:52
thank you for your kind answer 🙂 i was talking with the fitbit support and they checked my device. It turns out that the Surge I purchased from an authorize retailer in thailand has already been used. It was activated before with a different email address. I'm asking for my money back tomorrow. Thank you though
Best Answer08-28-2016 14:13
08-28-2016 14:13
@fluffypuppy maybe do an exchange and check the box to be sure it hasn't been opened first.
Customer support is very good and I'm glad they helped you.
Best Answer08-28-2016 23:22
08-28-2016 23:22
At least let the dealer know they sold you a used item, if you decide to keep it you deserve a discount.
