How to sync my surge when I'm traveling?
is there a way to sync my surge when I'm traveling and I don't have a dongle?  my device is not holding a charge,  could that be why?
Moderator edit: Clarified subject.
2 REPLIES 2
You need an internet connection and something to sync with such as a PC with either the charging cable attached and the Fitbit Connect software or a compatible mobile device.
Hi @hurl51l! Hope you are doing great and enjoying some healthy activities. Smiley Very Happy
Have you tried to use a mobile device as @SunsetRunner mentioned? You can download the Fitbit App if you have a compatible device. Log in into your Fitbit Account and give it a try. If you have an build-in Bluetooth pc you can sync via Bluetooth too, after downloading the Fitbit App for Window 10.
Hope this helps! Woman Very Happy
