01-12-2019
10:28
07:25
YojanaFitbit
01-12-2019
10:28
07:25
YojanaFitbit
So, for days I have been trying to get my Fitibit Surge to sync to my Honor 9 Lite and have been trying every thing I could find. I have FINALLY found something that works!
After downloading the Snyc Fix for Fitbit ap, I went through all the options without any sucess - until i got to the nuclear bomb option and downloaded the old version of the Fitbit ap (with the update disabled).
It turns out that the updated version of the ap is unstable with updates for older trackers like mine and as soon as i downloaded the old version of the ap it all works perfectly and as it should!
Moderator edit: Updated subject for clarity.
01-13-2019 07:23
01-13-2019 07:23
Hi @drprim nice to see you here on the Forums, welcome.
Thanks for all the steps that you've tried with your Surge. I think that you can try to sync with your Huawei in that way, great suggestion.
I'd like to mention that when trying to connect with a device that is not in the list of compatible devices, Fitbit can't assure it will work flawless since they are not fully tested. In the future, you have other options to keep using your Fitbit tracker after the update; you can sync or set up via computer, laptop, or any other compatible devices.
Other steps that you can try with your Surge after the update:
Requirements:
As a last resource, I would recommend following the steps below:
Make sure to check your phone Permissions and leave Location on to keep syncing and getting notifications with your phone, for more info check this suggestions from @ErickFitbit. ![]()
Hope this helps and welcome again! ![]()
