11-23-2020 04:09
11-23-2020 04:09
Ciao a tutti,
il cinturino del mio Surge, per quanto tenuto bene e con cura mi si è rotto.
Dove posso acquistarne uno nuovo?
grazie a tutti per le risposte.
Best Answer11-23-2020 07:36
11-23-2020 07:36
the strap of my Surge, although well kept and with care, broke.
Where can I buy a new one?
thanks everyone for the answers.
Welcome!
They are not repairable. Contact Support and see what they can offer you. Use Help at top of forum
Wendy | CA | Moto G6 Android
11-23-2020 07:36
11-23-2020 07:36
Welcome!
11-24-2020 13:00
11-24-2020 13:00
@RBord Fitbit doesn't sell replacement bands for the Surge. There are several sellers for them on Amazon, eBay, and other marketplaces. Many even include the tools necessary for removing the band. Replacing them is slightly tricky due to how the band attaches, so if you choose this route be careful and patient. There are many websites and Youtube videos. There is also a newer style silicon band for Surge I've seen that you just put the watch into, circumventing the need for future reinstallations. Try this link: https://www.google.com/search?q=fitbit+surge+band
Best Answer11-26-2020 11:05 - edited 11-26-2020 11:08
Amazon has replacement kits
I also found them on wish.com.
11-26-2020 14:05
11-26-2020 14:05
Yes, I'd mentioned Amazon. Here's a picture of the drop-in band I'd referenced in case helpful to find if interested, as it's available on Amazon, Wish, eBay, AliExpress, and other marketplaces. It allows you to put the tracker into the band without tools, and unlike the traditional bands also protects the back. It's a rather neat concept. You can even find homemade hand-crafted Fitbit Surge bands on Etsy. I've attached the picture of the drop-in band, hopefully, this helps!
