Inconsistent Mile Splits
Hi
I bought the fitbit surge, to track my running. All I would like it to do after I've run a mile show me the split time of the mile, not show me my split time at '0.6, 1.2, 1.9' and so on..
Can you help please as I've got a marathon coming up and it's important that I know my mile splits
Thanks
Rhodri
3 REPLIES 3
Hi
I bought the fitbit surge, to track my running. All I would like it to do after I've run a mile is show me the split time of the mile, not show me my split time at '0.6, 1.2, 1.9' and so on..
Thanks
Rhodri
@RhodriHarris wrote:
Hi
Thanks
Rhodri
Go to the Dashboard and click on the little gear in the upper right corner. Then select the Surge tracker. Scroll down to run cues. Set it so you get an alert every mile. Every mile, there will pop up and give the time for the last mile.
I'm not sure if you can see this summary on the Surge afterwards, but it will be available on your dashboard after the device syncs.
Be sure your Surge is fully charged before the marathon. Good luck!
@RhodriHarris Welcome to our Fitbit Community! I'd like to know if the workaround that my friend @GershonSurge shared, helped you to get the split time of the mile you ran.
Catch ya later! Smiley Happy
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
