12-11-2016
08:18
06:28
YojanaFitbit
12-11-2016
08:18
06:28
YojanaFitbit
I don’t understand the instructions for setting the timer on my Fitbit Surge. Step 4 is “Select the minutes and seconds of the timer duration, then tap the check mark icon or press the Select button to set the timer.” Please can someone tell me exactly what to do to “Select the minutes and seconds”
Moderator edit: Clarified subject.
Best Answerto stop a running timer push bottom-right
to reset it push top-right
when finished, it resets itself
nothing strange, nothing hard.
Hey there, @NatalieK1! Welcome to the Family! Than you for jumping in to help @SunsetRunner! ![]()
@NatalieK1 If you have time please check our Discussions board where you will find other members sharing their experiences and tips for an active lifestyle. ![]()
I'll be looking forward to your new comments! ![]()
Hi @p40murf, welcome to the Forums! You will find all the details on how to use the timer, in the Fitbit Surge manual on page 11, it includes pictures. Hope this helps!
I'll be around! ![]()
Hi @p40murf, thanks for the clarification. You can set the minutes and seconds, by tapping on the gear icon with your fingers (see the upper right corner of the picture) with your fingers or pressing the upper right button when you get this screen:
There you can select the minutes and seconds of the timer duration, then tap on the check mark icon or press the Select button. If the Surge is nor responding you might have to restart it a couple of times.
Hope this helps! ![]()
