04-12-2016 01:46
04-12-2016 01:46
Over the last few days, I have had trouble syncing my Surge to any of my Android and Windows 10 devices. During my troubleshooting, I connected my old Fitbit Ultra to see if the apps could at least see that.
Unfortunately, I had left the Ultra in my backpack and it had been recording steps -- I thought it was dead as I had not charged it for two months. The Ultra was detected by my app, and then the Surge was detected after I played with the all day sync setting. Now my data shows almost double the amount of steps for some days.
The app has added together the steps from the Surge and the Ultra for the last week or so. Is there a way to edit the step counts for the days that are affected? I want to remove the added steps from my daily totals.
Best Answer04-12-2016 21:22
04-12-2016 21:22
Welcome to the Fitbit Community @Handles. It's great to have you here. I'm glad to hear that your Ultra is still working after so long. You should be able to negate steps from your account by following these instructions. Let me know how it goes.
Catch you later. ![]()
Best Answer04-12-2016 22:23
04-12-2016 22:23
Best Answer04-14-2016 12:45
04-14-2016 12:45
@Handles In order to negate data it won't be necessary knowing if the steps were recorded by the Ultra or by the Surge. The system will remove from the daily total, the amount of steps you consider extra. You can remove steps from your account even if they are not showing up as logged activities. If necessary, you want to check out your daily average steps here.
Regarding the syncing issues, please follow these steps, this might help to get you back on track. Additionally, you can set up your Surge as a replacement device to resolve the problems to sync. Rest assured, your synced data won't get affected.
Keep up the super stepping. ![]()
