Is my glass broken? (Surge)
Hello all
I just bought the surge and it's working great but I'm noticing a little sharp glare under the glass all the way against the frame to the right. I only see it when I tilt the watch sideways and light hits it. Is it cracked underneath or is it just made that way? Anyone else see this on theirs?
2 REPLIES 2
@Sabbathu welcome to the forums! Yikes, I'm sorry to see about your buddy. In that case, I recommend contacting our Support Team for a second opinion. When you contact them, send them this pic so that it's more explicit. I'm sure they will be willing to rapidly address your concerns. Good luck! Cat Wink
Mariam | Community Moderator, Fitbit
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
