08-05-2017 19:00
08-05-2017 19:00
I see that Moto E is listed on the device compatibility list, does this include Moto E4 (4th generation)?
08-06-2017 10:00
08-06-2017 10:00
It does not, but that does not mean it will not work. I have a new LG G6 that is not on the list and it works just fine. There are no guarantees though.
08-07-2017 19:57
08-07-2017 19:57
Can someone give me a concrete answer? I don't want to end up buying another phone and find out it does not get calls or text messages.
08-10-2017 13:20
08-10-2017 13:20
Does anybody know? There has to be someone who has a Moto E4 and a Fitbit? and should be able to say if it's compatible.
10-05-2017 14:44
10-05-2017 14:44
I've just bought a Moto E4, installed Fitbit app and it isn't syncing with my Fitbit. Still having to do it through my iPad.
10-05-2017 22:06
10-05-2017 22:06
my Moto G5s is not in the list, but works well with my Surge.
Moto E4 specifications read. No reason it doesn't work
10-07-2017 07:08
10-07-2017 07:08
10-11-2017 01:12
10-11-2017 01:12
I have a Moto G (3rd generation) that is not on the compatible list any more. I'm sure it was when I bought the phone? It used to sync not a problem, however after an App update on my phone it stopped working and was a real pain to sync. To sync my Surge to my phone now I need to go into my Bluetooth settings an manually connect my surge to my phone. I sometimes need to turn off my surge and then turn it on again before it connects. Once I have connected manually through Bluetooth it seems to sync OK, but can take a while. Needless to say because it does not connect automatically I no longer get any notifications. Not over happy, but at least it works. . . . . . . . . . . . . . . . . . . . . .sort of!
10-13-2017 02:29 - edited 10-13-2017 02:29
12 months ago- i gave up. Samsung s4 wouldnt stay synched. I have a wrok around that i synch with my laptop and it then gives me 2-3 phone synch till it gets tired and forgets the connection again .
Boggle.
My Moto X was a dream with this tracker.
https://community.fitbit.com/t5/Surge/My-surge-will-not-find-my-new-phone/m-p/1692126#M60274
12-05-2017 04:28
12-05-2017 04:28
Did you ever find out if a Moto E4 works with the Fitbit?
12-05-2017 04:42
12-05-2017 04:42
12-05-2017 13:34
12-05-2017 13:34
05-22-2018 07:35
05-22-2018 07:35
I just purchased the Fitbit Versa and the Moto E4 (from T-Mobile) this week and ALL my notifications are working so far. I'm very happy with it so far!
