Is there a way to replace the band for the Surge?
Can you replace band on a Fitbit surge with a Fitbit blaze band ? If not do they make a replacement band for the Fitbit surge ? If so where do I find one ?
Moderator edit: Clarified subject.
3 REPLIES 3
Considering that the Surge band is glued on, no it is not replaceable.
Ive also moved your Surge question to the Surge forum.
Hey @Mcarter1234 and @Rich_Laue, I hope you are doing great and enjoying some healthy activities, it's great to see you on board @Mcarter1234Woman Very Happy
As @Rich_Laue mentioned Fitbit Surge doesn't have exchangeable bands, but in case that you're having issues with the band; it can be handled by our Support Team, they can take a look in your warranty options and provide you with the best possible solution for this issue. You can reach them via email, chat or calling at (877) 623-4997, they work from 4am to 9pm (PT), from Monday to Sunday.
I'll be around if you have more questions. Cat Wink
In warranty? Live chat to support and get a new watch
Out of warranty? Buy a new surge with a 25 percent discount.
Or
Youtube has videos showing how to replace the band, contrary to opinion it can be done *if* you are careful. If you break it, well it is out of warranty anyway...
Use Google to buy a third party replacement band, they are cheap
