08-10-2016 11:22
08-10-2016 11:22
08-10-2016 15:18
08-10-2016 15:18
Hi @KerrL
If not already done, consider trying another usb port.
Normally not required since new, though feel free to check out the Fitbit Help Article:
URL: Click to go to the Fitbit Help Article 'My tracker's battery isn't charging'
How to clean the tracker? YouTube Video (By Craig) (For flex but similiar for other trackers)
http://www.youtube.com/watch?v=ezvXy9mKoGQ
Hope it helps
08-10-2016 15:24
08-10-2016 15:24
08-10-2016 16:03
08-10-2016 16:03
Fastest to exchange at the store of purchase with receipt as it sounds having a battery issue.
Consider exchanging for the Fitbit Blaze, as it has exchangeable bands (with a more secure wristband like the Surge), in case the band breaks of the Surge outside of warranty, a new tracker needs to be purchased..
It also has a coloured screen, possible to choose between classic, leather & metallic bands..
Classic & Leather bands in several colours available, it comes with a classic band, optional bands can be purchased seperately.
It costs a bit less then the Surge, for GPS (tracking exercises with gps option) it can use the GPS of the phone, though can be turned of if not needing to view a map of your walks..
08-16-2016 08:17
08-16-2016 08:17
Hey there @KerrL! It's a shame to hear that you're experiencing this inconvenience with your new Alta, if you have already tried charging it the way it says on the article that @SunsetRunner shared. If issue persists I recommend contacting the Support Team so they can review your device history and tell you the options.
Let me know the outcome!
