07-06-2016 14:02
07-06-2016 14:02
Best Answer07-10-2016 15:42
07-10-2016 15:42
Thanks for taking a break from stepping to visit the Community @Kevmos27. The fluorescent square in the right side is utilized internally by our team for testing and development purposes.
The square in the bottom left corner is a light sensor. It detects when you are in a place with no illumination and it turns the Backlight on.
The Backlight needs to be set "Auto" for it to work as mentioned above.
Hope to see you around more often. ![]()
