08-15-2016 16:13
08-15-2016 16:13
I biked to work today my fitbit Surge is set to pick up if i bike for more than 10mins, which it did i biked for 16mins. Thats fine but it also counted it as steps, un sure what to do
Best Answer08-17-2016 13:59
08-17-2016 13:59
@Shelbyfern welcome to the forums! Please note that Fitbit trackers have a finely tuned algorithm for step counting. The algorithm is designed to look for intensity and motion patterns that are most indicative of people walking and running. On bumpy trails it's possible that your tracker will register steps but these should be negligible in your overall stats.
If you'd like to negate those steps, then please follow the instructions by @EdsonFitbit on logging a driving activity. Hope this helps! ![]()
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
