09-19-2016 00:19 - edited 09-19-2016 00:32
How can to sync my Surge to computer when I lost the dongle?
In the lastest version, It always asks me to plug the dongle to conect the Surge. But I lost my dongle, I just have the cable.
I tried to conect my Surge by cable but I always ask to plug the Dongle, it said: Not found the device.
Help me, please!
p/s: I don't use smart phone because it takes me a lot of time.
Best Answer09-19-2016 00:28
09-19-2016 00:28
Do you have a compatible mobile device (phone, tablet...) that you could use to sync your Surge? The last list of compatible devices can be found at www.fitbit.com/devices
If not then you could buy a replacement dongle from the fitbit online store (depending on where you live). There is a link to the store at the top of this page.
Best Answer09-19-2016 00:43
09-19-2016 00:43
But I don't use smart phone and tablet.
And my Surge blutooth was damage too, example It restart when I double press left button, it restart when I press Blutooth On to Blutooth PAIR...
Despair!
Best Answer09-19-2016 00:53
09-19-2016 00:53
I think Fitbit need to upgrade the app to fix this problem
Best Answer09-19-2016 01:06
09-19-2016 01:06
I don't understand what fitbit can do to the app if the problem is that you have lost the dongle!?
Best Answer09-19-2016 18:16
09-19-2016 18:16
I lost the Dongle but I can not sync by cable. Do you understand?
Best Answer09-19-2016 18:22
09-19-2016 18:22
Before, if I did not plug dongle, I can sync by cable. Now it is impossible!
Best Answer09-19-2016 18:23 - edited 09-19-2016 18:25
why??
Best Answer09-19-2016 23:48
09-19-2016 23:48
Sorry but I don't know.
Best Answer09-23-2016 07:50
09-23-2016 07:50
It's nice to see you around the Community @thong, hope you're doing great today! ![]()
As @SteveH has mentioned, you can sync via a compatible smartphone if you have one while you are looking for your Dongle, or borrow a friend's Dongle, since any Fitbit dongle will sync any Fitbit.
If you lost yours you can purchase a new one by going at our Fitbit Store. The reason why your cable is not syncing is due to it's the charging cable and it doesn't have the Bluetooth as the Dongle does.
Some computers that can communicate with the tracker over Bluetooth also don't need the dongle. However, because a computer's Bluetooth signal can occasionally be weak or problematic, it's a good idea to keep the dongle nearby even if you usually sync without it.
The Bluetooth-equipped computers that don't generally require a dongle are:
Hope this helps!
