Map not uploading
So yesterday I ran my first Marathon. Fitbit was perfect from start to finish. Was really looking forward to reviewing my stats but the map won't download onto my app. Any ideas why?
6 REPLIES 6
Hey hey hey @GBaz! It is nice to see you around. Cat Happy Let me ask you something, sis you run the marathon in a place with many buildings, trees or something that could affect the GPS signal? If so, that is why sometimes your tracker doesn't record the route. If not, then perform a restart of your Surge by doing the following:
1. Press and hold the Home and Select buttons (left and bottom right) for 10 to 15 seconds, until you see the screen flash or start to dim.
2. Let go of the buttons.
3. After your screen turns completely off, wait 10 seconds and press the Home button to turn your Surge back on.
If you have trouble restarting your tracker, just hold down the buttons for a longer time; don't release them until you see the screen get significantly dimmer.
Keep me posted!
Heydy | Community Moderator, Fitbit
Just got new Surge. Tried a run last night got heartbeat and distance data but no GPS info. Tried hike mode today and again no GPS data just heartbeat and distance info. Sat confirmation buzz received before starting off.  Any help much appreiciated
Hi there, it downloaded finally! It had tracked perfectly as all the data was on the watch post marathon its just that the map wouldn't open on my app. All good now and happy to have as a momento and to be able to see my split times. Thanks for your help
Hi @macdowa, welcome to the Community! did you try the restart I suggested above? If not yet, I suggest you to follow the instructions on this post to do so.
@GBaz, sounds pretty good that you are getting your maps now and you are able to see your detailed data.
Keep me posted! Smiley Wink
Thanks for welcome.  I tried the restart and it worked straight away.
Many thanks
Thanks for the response @macdowa! I appreciate the update. Smiley Wink I'm pretty sure that this will also help other users who are having the same issue.
If you need anything else, please let me know! Smiley LOL
