08-17-2016 15:25
08-17-2016 15:25
Best Answer08-17-2016 15:53
08-17-2016 15:53
Hi @Suzskip
From the fitbit article
Place your tracker into a bowl of dry rice for 24 hours. This will extract any moisture that remains inside the device.
After your tracker has been in rice for 24 hours, attempt to restart your tracker.
Restart the tracker
URL: Click / Tap to open the Fitbit Help Article 'How do I restart the tracker?'
Hope it helps
Best Answer08-17-2016 18:37
08-17-2016 18:37
Moving to the surge forum.
Wendy | CA | Moto G6 Android
Best Answer08-17-2016 20:06
08-17-2016 20:06
08-18-2016 06:09
08-18-2016 06:09
@Suzskip wrote:
Okay I will try this tonight fingers crossed thanks
I have found just being in a bowl of rice isn't enough, it needs to be in a sealed food container of rice.
08-18-2016 08:13
08-18-2016 08:13
08-18-2016 09:02
08-19-2016 11:31
08-19-2016 11:31
Are you able to use your tracker again @Suzskip
Best Answer08-19-2016 16:28
08-19-2016 16:28
No my screen will still not swipe 😞 I have tried putting in rice for 24hrs also resetting the fit bit numersous times 😞
08-19-2016 18:08 - edited 08-19-2016 18:09
The support team can be contacted from the official contact page. Mention what you've already tried to speed things up.
Best Answer08-19-2016 19:12
08-19-2016 19:12
@Suzskip wrote:No my screen will still not swipe 😞 I have tried putting in rice for 24hrs also resetting the fit bit numersous times 😞
My surge spent a full week in a sealed food container of rice; the only times it came out was for charging, running, and other activities (needless to say my step count was way down for that week). After the week the screen cleared for the mostg part and the swipe function has started working intermittently, I am still "ricing" my tracker for four or five hours after every run and while it seems to be getting a bit better, I don't yet know if it'll ever be back to full functionality. That said, I remain optimistic.
