02-17-2016
16:53
16:37
VivisFitbit
02-17-2016
16:53
16:37
VivisFitbit
I noticed in the newest fitbit has the ability to remind you to move after an hour of non-movement. It is the most expensive fit bit of your line. It would be fantastic to have this feature. I keep buying the most current and I have bought the ifit to get the movement feature. I returned it an d tuned around the fitbit surge and then you came out with the Alta.
Moderator Edit: Subject for Clarity!
Best Answer02-18-2016 14:39
02-18-2016 14:39
I think he ment the surge is the most expensive and therefore should have the feature.
02-19-2016 08:23
02-19-2016 08:23
Best Answer02-19-2016 08:29
02-19-2016 08:29
@Cjmoore, absolutely. I agree completely that it would be nice. You can "make your own," by setting alarms. I think it allows 8 alarms to be set, so if you liked you could create an hourly alarm for during most of the day to do the same thing. It's not quite as fancy, but would give you more or less the same functionality.
MakMak | Community Council
02-19-2016 08:38
02-19-2016 08:38
02-19-2016 08:45 - edited 02-19-2016 08:58
@Cjmoore On your Dashboard go to settings. On the Left Hand side choose Silent Alarms Then Click Add alarm and enter your time Then you can choose repeat if you want it to go off daily and select the days.
I have mine set this way and it makes me get up and Move
Wendy | CA | Moto G6 Android
02-19-2016 08:52
02-19-2016 08:52
02-25-2016 15:49
02-25-2016 15:49
Hi Cjmoore, another option is to select the star burst clock face which will show you which minutes and how many minutes you have been active within any given hour. While there is no alarm to buzz you you can just see it every time you look at the time and it will also save you some battery usuage extending the time between recharges.
02-18-2016 07:48
02-18-2016 07:48
Hi, @Cjmoore, it would be nice if the older trackers had this feature. At this point, only the Alta will be released with the feature. It's the same price as the Charge, not the most expensive in the Fitbit line. The only other tracker they are promising this feature for at this point is a later software update for the Blaze.
02-18-2016 14:39
02-19-2016 08:23
02-19-2016 08:23
02-19-2016 08:29
02-19-2016 08:38
02-19-2016 08:38
02-19-2016 08:52
02-19-2016 08:52
02-19-2016 08:59
02-19-2016 08:59
Best Answer02-19-2016 09:00
02-19-2016 09:00
Glad I could help. Now I gotta go as its buzzing me telling me to move 🙂
Best Answer02-25-2016 15:49
02-25-2016 15:49
06-23-2017 12:55
06-23-2017 12:55
I cant find the suggested star face clock - mine is just showing analog,orbit,flare and digital? where do I find this please?
