02-26-2017 02:47
02-26-2017 02:47
I already red the other 'wont sync' topics but nothing helps...
Sometimes rebooting the Samsung phone helps, or using classic bluetooth connection.
But most of the time i have to try for hours for a sync ![]()
What can i do?
12-02-2017 18:27
12-02-2017 18:27
The above list of supported devices is a PDF from September 2015, so it's probably well out of date. The latest compatibility checker on the website is pretty useless though.
In this day and age, if an app/device is compatible with Android, it should work on ANY device that runs a compatible version of Android. Everything else I've come across works reliably on most Android devices. It's poor software from Fitbit that is the problem...
02-26-2017 08:52
02-26-2017 08:52
Is the device you are trying to sync to a supported device?
iOS: https://www.fitbit.com/content/assets/onezip/images/devices/Fitbit_SupportedDevices_iOS.pdf
Android: https://www.fitbit.com/content/assets/onezip/images/devices/Fitbit_SupportedDevices_Android.pdf
Windows: https://www.fitbit.com/content/assets/onezip/images/devices/Fitbit_SupportedDevices_Windows.pdf
Best Answer02-26-2017 10:36
02-26-2017 10:36
02-27-2017 00:37
02-27-2017 00:37
After a reboot of my Samsung S7 it synced immediately.
Now i have to reboot for each sync...
Maybe a small software issue?
Best Answer11-30-2017 16:10
11-30-2017 16:10
Nor is the S8 on the supported list!!:
Best Answer12-02-2017 18:27
12-02-2017 18:27
