03-17-2017 15:40
03-17-2017 15:40
I have observed that my Fitbit surge vibrates after getting fully charged and logs steps. It disturbs my sleep and have to disconnect the charge cable.
does anyone have this issue?
03-18-2017 13:39
03-18-2017 13:39
That could be happening if the connection to the FitBit isn't secure and it's disconnecting/reconnecting intermittently. The design of spring clips on the side of the connector isn't great and if the Surge or cable has some strain on it it will come out a bit and then spring back in causing it to vibrate on reconnect. Make sure the port on the Surge is clean and that the cable has no strain during charging to see if that helps.
03-18-2017 13:39
03-18-2017 13:39
03-21-2017 08:36
03-21-2017 08:36
Halo @jj415 thanks for stopping by! Thank you for your participation in the forums @TwoBit! ![]()
Thanks a million for the help @jj415, that's an excellent workaround. It's good to see that we have a lot of Fitbit experts around! ![]()
@jj415 Thanks for making @TwoBit's post as an accepted solution. Marking posts as solutions is a great way of thanking another community member, while also highlighting their solution; so that it may be discovered more easily by other community member's facing the same questions or issues as you. Feel free to come back in case you need anything else!
Have you checked our Discussions board? If you're into Fitbit and fitness you may enjoy other users' comments. Check this board What is the most interesting place that you have walked run? And have some fun interacting with other Fitbitters! ![]()
See you around! ![]()
Best Answer03-24-2017 20:38
03-24-2017 20:38
Somehow the issue has returned. It still vibrates and logs it as steps taken. This morning it had logged over 9000 steps. The belt is also torn and it cannot be replaced. So I have decided to throw it in the river and go for something else. Very disappointed with my surge. I did not expect to fail in such a short time.
Thanks for the reply from community. You guys are Great. Will miss you all as I may go to some other tracker.
thank you,
jay
04-03-2017 12:19
04-03-2017 12:19
Hi @jj415, thanks for getting back, sorry about the steps issues and about your Surge band! ![]()
If you're considering taking the option that our Support Team gave you, we'll be here to keep assisting you or if you want to enjoy of our Discussions board, feel free to look around! ![]()
We don't want to create frustration in our customers. Fitbit has been designed to provide motivation and help you to reach your daily goals to success. Please know that we provide feedback to our team based on community posts and we are always working on improving our devices and overall environment based on what you share here.
Hope to see you soon! ![]()
