06-04-2019 09:39
06-04-2019 09:39
Is there anything I can do about this to fix the issue?
Best Answer06-04-2019 12:50
06-04-2019 12:50
Welcome to the forums!
How old is it? As they do not last for ever. But you can try these steps
See this thread for charging best practices. If you are not charging it correctly you could be damaging the battery
Best Charging Practices
Hope to see you around the forums!
Wendy | CA | Moto G6 Android
Best Answer06-05-2019 08:20
06-05-2019 08:20
I got a surge second-hand and wish I had done some research about the battery life. £50 down the drain 😞
I have only wore it since about 10:30am and I've put it on charge already. Just sinc up and it says it has a full battery already after about 20 minutes.....wish I never bothered at all 😞
