04-21-2018 09:59
04-21-2018 09:59
When i ran fast my watch show me HR 156 but at the same timei was HR belt with different watch also and that one show me 178 such big difference .
At least never my HR come mor than 184 up to now , but some of my ecexerci bring my HR even close to 200
Can i fix my issue ? Or not
04-25-2018 06:36 - edited 04-25-2018 06:39
Hope you are doing great and enjoying some healthy activities @Armanmajidiii. Thanks for jumping in @supersmart01234
Our PurePulse heart rate tracking is the only heart rate technology to offer automatic, continuous wrist based tracking for all-day health insights and workout intensity. It is uniquely designed to measure heart rate all day, with always-on optical heart rate sensors that still maintain extended battery life also. PurePulse allows you to accurately track workout intensity and calorie burn with finely tuned algorithms that provide insight through interactive charts and graphs.
You can read some tips to improve accuracy since occasionally your tracker may have difficulty getting a strong signal. If you don't see your heart rate on your tracker, first make sure you are wearing it correctly. Experiment with placing the tracker higher on your wrist; because blood flow in your arm increases the farther up you go, moving the tracker up a couple inches can be helpful. Also, make sure you're not wearing your tracker too tightly; a tight band restricts blood flow, potentially affecting the heart rate signal.
Though we've found that PurePulse provides better overall heart rate tracking than cardio machines or chest straps since it tracks your heart rate day and night, wrist placement during certain vigorous exercise is important but chest straps might be more accurate for this type of exercises as they are wore near to the heart. After a short wait, you should see your correct heart rate showing off. If this reading persists, try changing your Heart Rate setting from "Auto," which means the heart rate tracker is usually active when you're moving, to "On," which means the heart rate tracker is always active.
Hope this helps, I'll be around!
04-21-2018 12:10
04-21-2018 12:10
@Armanmajidiii wrote:When i ran fast my watch show me HR 156 but at the same timei was HR belt with different watch also and that one show me 178 such big difference .
No, Optical wrist heart rate machines will never be as accurate as chest straps. Maybe in the future but not with today’s tech.
