11-17-2016
03:16
18:37
EstuardoFitbit
11-17-2016
03:16
18:37
EstuardoFitbit
I bought a Surge from Amazon. Hooked it up and got it connected to my LG4. I notice it doesn't keep up with my steps online or anything automatically. I don't know what setting i have turned off. Also when i tell it to "manually sync up" it just keeps turning in circles.
EDIT: I let the sync keep spinning, and it eventually gave me a red explination point.
EDIT 2: FIxed it myself. Restarted surge didn't work. forcing it to stop cutting blue tooth off/on didn't work. Restarting my app didn't work.
I cut off my phone, took battery out, while app was "Forced stopped and blue tooth on". Restarted phone and then it connected.
Best Answer11-18-2016 05:56
11-18-2016 05:56
A warm welcome to the Community @Puthy. Thanks for troubleshooting this inconvenience by yourself. If your tracker is not connecting with your phone, please check that your device is a compatible mobile device. If it is, follow our syncing troubleshoot.
Let me know the outcome. ![]()
