Need help:failed to update the firmware for the Surge
I updated the firmware for the surge,but my surge does not display completely except the battery icon. How can I fix the problem. Thanks
1 REPLY 1
Welcome to the Fitbit Community @zuoxing, just to confirm, after you performed a firmware update you're no longer able to see all the options on the Surge's dis[;ay and you only see the battery icon?
Before considering other options, try to restart your tracker at least a couple of times if you haven't done so already, this has helped other users who were experiencing similar difficulties with the display. I hope this helps, keep me posted.
