12-03-2017
03:37
06:09
YojanaFitbit
12-03-2017
03:37
06:09
YojanaFitbit
Hi i have just need to know where do i send my fitbit surge for repair as the band had broken and i need a new band please need more info
12-03-2017 05:47
12-03-2017 05:47
Hi
12-06-2017 06:16
12-06-2017 06:16
Hope you are doing great and enjoying some healthy activities @arieta. Thanks for the suggestion @SunsetRunner! ![]()
I've requested to our Support team to create a case on your behalf. You should soon receive an email from Customer Support at the email you used to register with the Community forums.
Let me know if you have questions about it.
12-06-2017 14:18
12-06-2017 14:18
@arieta. None of Fitbit's devices are "repairable". Some have replaceable bands. The Surge is not one of them (by Fitbit standards). Aftermarket bands are available from Amazon and ebay while YouTube has helpful "How To" video's on replacing the band. One final note. The Surge has been discontinued and replaced by the Ionic. Best of luck to you.
09-16-2018 08:16
09-16-2018 08:16
I need to find out where to send my fitbit surge in for repair. It has a broken face piece and band.
09-19-2018 09:49
09-19-2018 09:49
Hi @Ranchloop, Thanks for taking a break from stepping
In regards to your inquiry, Fitbit doesn't have a repair center to replace the display or just to sell that specific part. It's best to check with our Support Team your warranty options, please wait for a follow up email. They will be happy to help. Let me know if you have questions about it.
I'll be around.
