10-15-2017 23:42
10-15-2017 23:42
I have been unable to sync my Fitbit for nearly 2weeks now, also for some reason I can only check my history as far back as August 2017 but Iv had the watch over 2 years and have always been able to view stats from the first day I used it. Has anyone else had issues lately. Any help with be most appreciated.
Cheers Rob
10-20-2017 12:00
10-20-2017 12:00
It's great to have you here @Hillsideave! I would like you to try this syncing troubleshooting. Regarding your question about your 2 years' data that you're not able to see it, sometimes users accidentally create another account, with a similar email address. That's why it's not showing the old data that you previously had.
I would like you to double check that you're logged into the same account that you were before.
Hope this helps! Keep me posted.
10-23-2017 01:42
10-23-2017 01:42
10-23-2017 07:09
10-23-2017 07:09
Thanks for those details @Hillsideave! Have you make sure that you're logged into the same account that you were before? Could you provide me with a screenshot of what screen you're getting in your app? Once, your Surge is set up to your account, there's no need to do this process again. You just need to log in and turn on Bluetooth, it should automatically sync.
Keep me posted!
10-23-2017 10:58
10-23-2017 10:58
Hi Silvia
Thank you for the reply
I’m still not sure why the app did not open as usual. After setting my own new password and not useing the one provided by Fitbit and then exiting and opening the app it all seems to be ok. They do make it hard some times Fitbit 😀 thanks again
