01-05-2016 13:22
01-05-2016 13:22
Does fitbit surge work with a Nokia 920 ? I have managed to install the fitbit connect program to my laptop for syncing etc , but I would like to use it on my windows phone / nokia 920. Is there an update or fix to get my windows phone to work?
01-05-2016 13:53
01-05-2016 13:53
Hello @chrisblue,
Assuming you have at least Windows Phone 8.1 on your Nokia Lumia 920, you'll be able to run and sync your Fitbit with the Fitbit App (just log in to the same account that you do online). Just search for it on the Store.
Note: You don't pair your Fitbit directly with your phone. Just run the app, log in, and allow it to do its thing.
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
