03-01-2016 06:44
03-01-2016 06:44
One of the green flashing lights just went out on my surge. It still registers my heart rate. Is this, or will this be an issue in the future? Is there a way to turn the one light back on? I did a reboot, and my setting is set to Auto. Thanks in advance.
03-03-2016 09:14
03-03-2016 09:14
03-14-2016 13:07
03-14-2016 13:07
Hi ..thanks for the assistance. I tried all that you said, but i still only have the one light on; and the other is off. It doesnt seem to be affecting the surge's use, but its worrisome that something is wrong.
ANy other suggestions?
Thanks
John
05-06-2016 16:34
05-06-2016 16:34
Hey @jjpezpal, Besides @MaginB's advice, you can also try to switch your heart rate settings from "On" or "Auto" to "Off", save and sync your tracker. Then turn the heart rate back to "On" or "Auto", save and sync your Surge. This will let you know if you heart rate sensors are working fine. If after doing this the issue persists, contact our Support folks.
Keep me posted.
