05-03-2016 15:13
05-03-2016 15:13
Best Answer05-04-2016 03:25
05-04-2016 03:25
I've been out of bed for five hours and Im on 2000 calories already. Can a fitbit represenative please give me some idea how to correct this fault. I hit 4000 again yesterday without much effort. Thanks
Best Answer07-18-2016 06:39
07-18-2016 06:39
Hi there @stockie12. Good to see you around.
I noticed that your post didn't have a response so I wanted to jump in to check if you still need help with this.
The behaviour you mention doesn't sound any good at all. I would recommend in the case you're still having the same problem, to restart your tracker by pressing the left and lower right buttons together for 10-12 seconds. You will see the display dimming until it turns off and then, just press any button to make it come back on. This should readjust the tracker and fix this and also, in your profile, make sure that information as your height, weight, stride length and other personal information has been correctly entered.
Let me know if you need more help.
